locke
2 years agoError "Unknown device part" when start complete flow within jenkins
Hello, I try to build our Arria10 project in all revisions within jenkins (on win11). I've tried this with Quartus Prime Pro 21.2 and 23.4. What I do is simply quartus_sh.exe --flow compile <proj...
- 2 years ago
If so, the root cause should be the license issue.
Please make sure the machine that the job lands on can access the license server.
TingJiangT_Intel
Contributor
2 years agoHave you set quartus related environment variable correctly? You can try other devices to see if the same issue occurs.
If you can use quartus locally, the problem will be caused by the remote server you are using.
locke
2 years agoI just have these in the environment, and coudn't identify more/other Quartus-related envs for a local user
QSYS_ROOTDIR='C:\intelFPGA_pro\23.4\quartus\..\qsys\bin' QUARTUS_ROOTDIR='C:\intelFPGA_pro\23.4\quartus'
