17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
11 years agoI've faced the same error. In my case, issue was caused by EOL (End of line) Format. My notepad ++ used LF (Old Mac) Format by default (don't know why).
I solved the issue by converting EOL to Windows Format: Edit -> EOL Conversion -> Windows Format Default EOL Format in notepad ++ can be set: "Settings" -> "Preferences" -> "New Document/Default Directory" then select "Windows" (if you are Windows user offcourse :)) Hope this will help someone. Regards, Nemanja
