17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
17 years ago --- Quote Start --- I was not able to get any *.qar file. The message I got after archiving was: "Project archiving created; however, Analysis Elaboration was not successful. As a result, some files could not be archived". None of the output files complied with the attachment format; therefore I could not upload any files for you to examine. Any ideas please. Regards, SML --- Quote End --- Hi, tricky problem. I think you can only archive a project which successfully fits. If your project is small put the quartus run directory and your source files in a zip file. The Zip file could be attached to the post. Kind regards GPK
