17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
17 years ago --- Quote Start --- Hi... Thanks for the reply.... There is no space character in the name. Is there any specific location like 'bin' folder where the files has to be stored while simulating the program? Please help me with this.. Thanks --- Quote End --- Hi, you can check whether the file is in the project or not. Project -> Add/Remove Files in Project There you can see all the files which are used in the project. If you don't see your top-level files use the "add" button to include the file. Btw: Did you use the Project wizard for setting up your project ?
