17 years agoError: top level design entity " " is undefined
we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case se...
17 years ago --- Quote Start --- we have problem in compiling VHDL code in Quartus II software. Every time we compile it shows the Error:top level design entity " file name" is undefined. We are even taking care of the case sensitivity. Our file name, new created project name and entity name in the code are all same. Plz help us regarding this. --- Quote End --- Hi, did you set the toplevel correctly ? You can check that in Quartus : Assignments -> Device -> General Look to the field "Toplevel entity". If this is not your toplevel, write it down here. Kind regards
