ERROR (RUN FUNCTIONAL SIMULATION)
**** Running the ModelSim simulation ****
c:/intelfpga_lite/23.1std/questa_fse/win64//vsim -c -do assignment2.do
** Fatal: Failed to initialize licensing environment. License environment not set correctly.
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
Error.
WHY, HOW CAN I SOLVE IT???
- RichardT_altera
Check that you have set up a license for Questa Intel FPGA Starter Edition.
Please check the step-by-step guide below:
https://www.intel.com/content/www/us/en/docs/programmable/683472/24-3/and-software-license.html
Richard Tan
- nicky05
i use Quartus® Prime Lite Edition. It says that tjis edition do not need to have license, so is it same as Questa Intel FPGA Starter Edition? - nicky05
How to solve this? Can you tell me the steps ?
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Error.
- sstrell
Even Lite requires a no-cost license. Generate the license and then add an LM_LICENSE_FILE environment variable to point to the file you generate.
- RichardT_altera
You will need to set up license for Questa even you are using Quartus lite. The tool will checkout the Questa license when running the simulation waveform tool in Quartus.
Please check the table below regarding the "Summary of Intel FPGA Software Licenses Required":
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you.
Do you need any further assistance from my side?
Richard Tan
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Richard Tan
