18 years agoError: Project too complex: hierarchy path is too long
hi, i have created my custom instruction hardware and created a nios system, system generation was successful but the Quartus II compilation (after system generation) was unsuccessful with display...
13 years agoThis is a Windows* OS/file system issue.The cause is directory paths on the drive is longer than 255 characters (including spaces).There's a lot of additional softwares which can fix this problem like Long Path Tool.
PathTooDeep.com Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename. I hope that it will help you! Good luck! Cheers!
