12 years ago
Error on simulation: Quartus 13.1 + Qsim + Modelsim
I am trying to simulate using vwf files in Quartus 13.1 + Qsim. I create the vector waveform file and then I try to
run a functional simulation, but I got the error below
# ** Error: (vsim-3170) Could not find 'work.mydesign_vlg_vec_tst'.
# Error loading design
Error.
I believe this vlg is related to verilog (my hardware descriptions are in vhdl). There is only one file
named mydesign.vhd in my project. Any ideas of what is the problem?
Thank you all
    I have the same problem when I use one separate file of constants.
    Have you already found a solution to this problem?
    --- Quote Start ---
    Error.
    Thank you all
    --- Quote End ---
    Have you managed to solve the problem guys? I'm facing the same issue!
    --- Quote Start ---
    --- Quote End ---
    No, I haven't
