Amit4's avatar
Amit4
2 years ago
Error: Invalid license environment. Application closing.
I was trying to simulate my program but it gave this error:
Error: ** Fatal: Failed to initialize licensing environment. License environment not set correctly.
Info: Unable to checkout a license. Vsim is closing.
Error: ** Error: Invalid license environment. Application closing.
Error: Compilation was NOT successful. 2 errors, 0 warnings
  • sstrell's avatar
    sstrell
    Just like it says, you need a license. You don't mention what software this is or any details.
  • Amit4's avatar
    Amit4
    I am using Intel Quartus Prime Pro. I also have the license in the form of a .dat file. I have given the path in the option of the License Setup in the tools option.
    • sstrell's avatar
      sstrell
      That’s for Quartus. Assuming this is for Questasim, you have to set up the LMS_LICENSE_FILE environmental variable to point to the file.
      • Amit4's avatar
        Amit4
        Thank you for your response..yes this is for Questa Sim.
        Now the previous error is not coming...but in the tools menu there is no run simulation option...please help me with it.
  • AR_A_Intel's avatar
    AR_A_Intel
    Hello
    Welcome to INTEL. We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    To further check, may we know whether the license issue has been resolved on your end, or if you're still encountering any problems?
    AR_A_Intel
    As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
