14 years agoError in "Run as -> Nios II Modelsim" using Eclipse SBT
Hello: I'm using Quartus 11.1 under Ubuntu 11.10. I've been following this(altera.com/support/examples/nios2/exm-simulating-niosii.html) tutorial, trying to simulate a system created with...
14 years agoFinally, I found an answer in this post: alteraforum.com/forum/showthread.php?t=32760
One point that we have found with Ubuntu. Most things do work well, however the issue that you mention in your note is very similar to some other .sh issues that we have seen. On Ubuntu, this is commonly resolved by changing the symbolic link for /bin/sh from /bin/dash to /bin/bash:
sudo rm /bin/sh
sudo ln -s /bin/bash /bin/sh
Dash and Bash have a slightly different syntax, and that gets us around most issues. This solution worked for me :)
