14 years ago
Error: "Failed to refresh PTF file" Windows 7 and Quartus 10.1
I have just acquired a new computer with Window 7 installed.
After installing Quartus 10.1, I have tested one of the SOPC systems developed on the old computer which was running WinXP SP2.
While generating the system I have encountered the following error messages:
Info: Starting PTF file elaboration.
0 [main] sh 38524 child_copy: stack write copy failed, 0x28C4C0..0x290000, done 0, windows pid 38524, Win32 error 487
247 [main] sh 38524 fork: child 39344 - pid 39344, exitval 0x103, errno 11
/usr/bin/sh: fork: Resource temporarily unavailable
Error: Failed to refresh PTF file
Info: Finished elaborating PTF file.
Executing: C:/altera/80/quartus//sopc_builder/bin/sopc_builder --classic --generate C:/altera/Projects80/nrg_a/main/nios_sys.ptf
Info: Starting generation...
0 [main] sh 40064 child_copy: stack write copy failed, 0x28C4D0..0x290000, done 0, windows pid 40064, Win32 error 487
394 [main] sh 40064 fork: child 40356 - pid 40356, exitval 0x103, errno 11
Error: System generation failed.
In the attempt to resolve this problem I have taken the following actions:
1. turned off the Virus Scan (from CA);
2. turned off the Firewall;
3. turned off the UAC;
Furthermore, I have created a test SOPC system (with CPU, EPCS, RAM, SYSID and JTAG) and attempted to generate it under the following environments:
1. Quartus 8.0 32 bit SOPC;
2. Quartus 8.0 64 bit SOPC;
3. Quartus 10.1 32 bit SOPC;
4. Quartus 10.1 64 bit SOPC;
5. Quartus 10.1 32 bit QSYS;
6. Quartus 10.1 64 bit QSYS;
in all cases I am not able to generate the system because errors are occurring whenever the PTF file is going to be generated.
I will really appreciate some support on this issue if anyone of You had experienced similar problem.
Thanks and regards,
    i've seen this error before, i think its a cygwin issue
    if you're in a real bind then i would install CentOS in a virtual machine
    Thanks a lot for proving that I was not the only one!!!
    I finally have been able to generate the system without problems only after uninstalling the antivirus: CA Security Suite, for which I have a legal copy and I have been using it together with Quartus II and the SoPC on my older computer under WinXP environment.
    The amazing has been that even if I had Snoozed the Anti-Virus, I was getting the compatibility problem; again, never experienced this before.
    Conclusion: I am now using Windows Defender and everything is working fine, again and finally. A total of 16 hours and 2 sleepless nights to figure it out. :D
    --- Quote Start ---
    --- Quote End ---
    Can you help me this problem "Failed to refresh PTF file"? Please, you can show me your resolve the problem
