12 years agoError CODE VHDL in Structural model
Hi All.
I am new VHDL and I see a error when coding: Can YOU help me! Error (10348): VHDL type mismatch error at DDS_test.vhd(37): type of formal parameter "out_cos" does not match port type of value Error (10482): VHDL error at DDS_test.vhd(37): object "bcd" is used but not declared Error (10558): VHDL error at DDS_test.vhd(37): cannot associate formal port "out_cos" of mode "object" with an expression Error (10346): VHDL error at DDS_test.vhd(35): formal port or parameter "bcd" must have actual or default value Error (10784): HDL error at DDS_test.vhd(25): see declaration for object "bcd" -------------------------------- -------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity DDS_test is port( clk: in std_logic; rst: in std_logic; enb : in std_logic; HEX: out std_logic_vector(20 downto 0) ); end DDS_test; architecture bv of DDS_test is signal out_cos: std_logic_vector(11 downto 0); component DDS_cos port( clk: in std_logic; enb: in std_logic; rst: in std_logic; out_cos: out std_logic_vector(11 downto 0)); end component; component test port( clk : in std_logic; bcd : in std_logic_vector(3 downto 0); --BCD input Segs : out std_logic_vector(6 downto 0) -- 7 bit decoded output. ); end component; begin DDScos: DDS_cos port map ( clk=>clk, rst=>rst, enb=>enb, out_cos=>out_cos); test1: test port map ( clk=>clk, out_cos(3 downto 0)=>bcd, Segs=>HEX(6 downto 0)); test2: test port map ( clk=>clk, out_cos(7 downto 4)=>bcd, Segs=>HEX(13 downto 8)); test3: test port map ( clk=>clk, out_cos(11 downto 8)=>bcd, Segs=>HEX(20 downto 14)); end bv; THANKS SO MUCH!
