12 years ago
Error: Can't simulate mismatched node types
Good day, I design ALU (arithmetic and logic unit) in the language of Verilog HDL. When I try to simulate the circuit though I get these errors:
--- Quote Start ---
Warning: Wrong node type for node "result[0]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[1]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[2]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[3]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[4]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[5]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[6]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "result[7]" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "flagZ" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "flagO" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Warning: Wrong node type for node "flagN" in vector source file. Design node is of type Output, but signal in vector source file is of type Input.
Error: Quartus II 64-Bit Simulator was unsuccessful. 11 errors, 11 warnings
--- Quote End ---
What am I doing wrong here?
P.S. I live in Russia, and does not know very well English. Forgive my ignorance.
1 Reply
    I don't think so there is any problem in your source code.I think problem is in your test bench. So please provide your test bench.
    I found one typo error in your source line 271.It should be z = (res == 0) ? 1 : 0 instead of z = (res=0) ? 1 : 0.
