17 years ago
Error: Can't place pin mem_dq[2] to location R8
I build a project of cycloneIII including CFI,SSRAM,DDR SDRAM,PIO,JTAG and PLL.
But when I fit it there is the error as show below:
Error: Can't place pin mem_dq[2] to location R8.
Error: Too many output and bidirectional pins in I/O bank 3 assigned near VREF pin T6 (VREFGROUP_B3_N0) on device EP3C25F324C8 -- no more than 9 output and bidirectional pins allowed near the VREF pin when voltage referenced pins are driving in, but there are potentially 10 pins driving out
Info: Pin mem_addr[1] of type output at location U5 uses SSTL-2 Class I I/O standard
Info: Pin mem_dqs[1] of type output at location T8 uses SSTL-2 Class I I/O standard
Info: Pin mem_addr[4] of type output at location P8 uses SSTL-2 Class I I/O standard
Info: Pin mem_addr[2] of type output at location U7 uses SSTL-2 Class I I/O standard
Info: Pin mem_addr[3] of type output at location U8 uses SSTL-2 Class I I/O standard
How to get over it? I try many ways.
But if I build a project no CFI and SSRAM, it fit successful.
My board is CycloneIII starter board and pin assigned as reference.
Thank you.
    As far as I see, the cycloneiii_3c25_start_niosii_standard is using the same resources and compiles without errors. Did you import the DDR RAM design *.tcl files, particularly the pin assignments, including the output-enable-group assignments for bidirectional DDR pins?
    If all necessary settings are in effect and the error would be due to an incompatible pin assignement of the Evalboard, some outputs in the B3_N0 Vref group may be declared static by assigning a ToggleRate of 0 MHz to them. They are ignored for I/O pin distance rules then.
    --- Quote Start ---
    --- Quote End ---
    the error is occured yet.
    the DDR RAM design *.tcl files have imported. and the direction of pins are right.
    I didn't understand
    --- Quote Start ---
    --- Quote End ---
    and how to correct it.
    - Did you check the design differences to cycloneIII_3c25_start_niosII_standard?
    - Search for "toggle rate 0MHz" in Altera Knowledgebase.
