AK225
2 years agoError: Can't launch Questa Intel FPGA Simulation software.
Hi, I'm unable to launch a simulation for a project and I keep getting the following error: I'm using Quartus Prime Lite Edition 21.1 with a generated free license from Intel "Questa*-Intel® ...
AK225
2 years agoThe following is the Error log from Quartus:
Info: Start Nativelink Simulation process
Info: NativeLink has detected Verilog design -- Verilog simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : max10
Quartus root : c:/intelfpga_lite/21.1/quartus/bin64/
Quartus sim root : c:/intelfpga_lite/21.1/quartus/eda/sim_lib
Simulation Tool : questa intel fpga
Simulation Language : verilog
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\modelsim
Info: Starting NativeLink simulation with Questa Intel FPGA software
Sourced NativeLink script c:/intelfpga_lite/21.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Error: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: issued_nl_message
Nativelink TCL script failed with errorInfo: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
while executing
"error "$emsg" "" "issued_nl_message""
invoked from within
"if [ catch {exec $vsim_cmd -version} version_str] {
set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..."
(procedure "launch_sim" line 88)
invoked from within
"launch_sim launch_args_hash"
("eval" body line 1)
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if [ info exists ::errorCode ] {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $..."
invoked from within
"if [catch {eval launch_sim launch_args_hash} result ] {
set status 1
set save..."
(procedure "run_sim" line 74)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
error "$result" $savedInfo ..."
(procedure "run_eda_simulation_tool" line 334)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
