12 years agoError: Can't find the instance. Download a design with SRAM Object File containing t
when i perform sigtap ii ,the project don't have any problem before. but recently i add some module to it and use modelsim to simultate it ,then when i perform it again,it shows that
"Error: Can't find the instance. Download a design with SRAM Object File containing this instance." what is the problem. i can sure that the .sof file is updated correctly. when i perform the project which duplicated it from the right operation file before , it workes well. then, i modify the width of the fir filter's output data,it fail to work.when i change the width back to 35 ,it works well again. it seems that the width can only be set to 35,what is the problem? finally,i find the question is the project can't change anything .if you change it ,it can't work,if you change the modification back ,sigtap works well. please ,help me find the question.
