12 years agoHi,
So to summarize (as I understand it): There is no indication in the map report that the stp-file is pointing towards illegal nodes in the design. The signaltap instance is present in the fitter report. If the width of the FIR-filter is other than 35 bits the signaltap sw can't connect to the debug core. To be honest, I'm not sure what's going wrong here... Have you tried to create a new signaltap instance from scratch with the newest version of the project? Cheers J
