12 years agoHi,
It's a bit hard to speculate about that without knowing which different devices you have been using, or the nature of the design. Do you mean that the design only works when the width is 35 bits, or do you mean that it's only possible to see the SignalTap instance when the width is 35 bits? By saying that everything is OK, do you mean that the design indeed works as intended in HW? Regards J
