8 years agoError: Can't assign node "<name_pll>" to any location (ID: 176359)
Has anybody came across this error? After hours of searching, I can't find anything on this.
I only get this error when I try to drive 8 or more register from one of the ALTPLL output. Error: Can't assign node "name_altpll:auto_generated|wire_pll1_clk[0]" to any location (ID: 176359)7 Replies
Can post some part of your code? I have tried to drive 8 registers and it was without any error. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
My apologies, I meant 14 registers or more. I'm trying to drive 14 register with clk27M. Here is a snippet of the code with 4 registers; there are 14 registers using this clk in total.
PLL PLL(.inclk(clk50M), .c0(clkA), .c1(clkB), .c2(clkC), .c3(clkD), .locked(pll_lock)); reg [7:0] a = '0; always @ (posedge clkA) a = (some conditional statement) ? a + 1 : 0; reg[31:0][7:0] b = '0; always @ (posedge clkA) b[a[7:0]] = (some conditional statement) ? data : b[a[7:0]]; Thank you - Altera_Forum
My apologies, I meant 14 or more registers. I'm trying to drive 14 registers from the output of the ALTPLL with 27M and input of 50M.
--- Quote Start --- My apologies, I meant 14 or more registers. I'm trying to drive 14 registers from the output of the ALTPLL with 27M and input of 50M. --- Quote End --- Hi, Which device you are using? We can drive 14 or more registers, which depends on Number of LE available on device (FPGA) Do check the code again. i have tried to reproduce the error but it was successful compilation Check the image. https://alteraforum.com/forum/attachment.php?attachmentid=14651&stc=1 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Check the following link which may help you on the error. http://quartushelp.altera.com/14.1/mergedprojects/msgs/msgs/efitcc_fitcc_type_of_atom_location_assigned_mismatch.htm Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
I didn't modify the .qsf file manually so I don't think this applies to my current error.
