8 years agoError: Can't assign node "<name_pll>" to any location (ID: 176359)
Has anybody came across this error? After hours of searching, I can't find anything on this. I only get this error when I try to drive 8 or more register from one of the ALTPLL output. Err...
8 years ago --- Quote Start --- My apologies, I meant 14 or more registers. I'm trying to drive 14 registers from the output of the ALTPLL with 27M and input of 50M. --- Quote End --- Hi, Which device you are using? We can drive 14 or more registers, which depends on Number of LE available on device (FPGA) Do check the code again. i have tried to reproduce the error but it was successful compilation Check the image. https://alteraforum.com/forum/attachment.php?attachmentid=14651&stc=1 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
