11 years ago
Error (293007): Current module quartus_map ended unexpectedly
I am trying to compile the hello_world opencl example. I got the emulator version working fine. Am now trying to build the hardware version.
Compile line is
aoc device/hello_world.cl -o bin/hello_world.aocx --board s5_ref
After 20 minutes it fails with following message
Error: Compiler Error, not able to generate hardware
The following is the tail end of the quartus_sh_compile.log file
Info (12128): Elaborating entity "system_mm_interconnect_2" for hierarchy "system:system_inst|system_mm_int
Error: Flow compile (for project /home/mps/altera_projects/mhello/mhello/top) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message
No other log or report files seem to have anything worth mentioning.
Thanks for any help. PS using linux redhat, version 14.1 of quartus.
    How much memory do you have? I sometimes see this when quartus runs out of memory.
    Excellent! I see from my system logs that quartus_map does in fact get killed because it runs out of memory.
    I only have 4GB and no swap, am trying again with swap=16GB.
