Error (293007): Current module quartus_fit ended unexpectedly
Unfortunately, I am having problems logging into Intel with my work email. That is why I have just created a private Intel account and I am responding using this account.
I have tried the following two things:
3) "Can you try quartus --reset_desktop to see if it helps?"
I went to the installation directory c:\intelFPGA_lite\24.1std\quartus\bin64\ and opened a command line window there, where I entered quartus -reset_desktop. The error persists.
4) "In the C:\Users\<user>\ directory there is a quartus2.qreg file, delete it and see if it helps."
I have deleted the file. The error persists.
7) Run quartus_fit.exe on the project in the command line.
I can't find a quartus_fit.exe file,
only quartus_fit.pdb under c:intelFPGA_lite\24.1std\quartus\bin64\pdbmin\.
How should I start it? I can set a path to this file and than I can start quartus_fit.pdb in the project directory?
I will be in touch again next week.
Stephan
This morning, I was able to verify that the quartus_fit.exe file is missing from the computers on which the fit function does not work. It cannot be found in the same location as on the computers where the fit function works. I checked this on several computers.
Best regards
Stephan
- StephanBoruckiPrivat1 year ago
I will reinstall Quartus Lite tomorrow on the computer, where the quartus_fit.exe is missing. I will seach for quartus_fit.exe. I'll expect it to be there then. The I'll try to start quartus_fit.exe in the command line.
I would like to ask again how I can run quartus_fit.exe in the command line?
