Error (293007): Current module quartus_fit ended unexpectedly
Hi @NTA ,
Additionally, please try the following:
In the, GUI, run Analysis & Synthesis.
Then exit the GUI.
On the command line, run quartus_fit.exe on the project.
What exactly is meant by "the quartus installation becomes corrupt and not even a re-install fixes it"? Is that referring to this specific error message (293007) from quartus_fit or is there any other symptom?
And to make sure I understand: after this error is generated, does the exactly same error occur for ANY other project located anywhere (network or local)?
What is the license setup?
Also, after the error, does running the Quartus menu command Project > Clean Project... followed by a fresh compilation fix the issue? If not, then try to manually delete all quartus-generated subdirectories and files in the project directory and try again. For example, delete the entire 'db', 'incremental_db', 'output_files' directories.
Have someone download the Free edition of Microsoft Visual Studio C++: https://visualstudio.microsoft.com/vs/community/
And then try to either run quartus_fit.exe from inside the IDE, or when quartus_fit.exe crashes, the Just-In-Time debugger prompt should appear to attach to the process in the IDE and hopefully we can get a callstack.
Richard Tan
