8 years ago
Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl
Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini
Info (125061): Changed top-level design entity name to "top"
Info (125061): Changed top-level design entity name to "kernel_system"
Info (16677): Loading synthesized database
Info (16734): Loading "synthesized" snapshot for partition "|".
Info (16678): Successfully loaded synthesized database: elapsed time is 00:00:29
Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 12152 megabytes
Error: Processing ended: Wed Nov 15 01:19:43 2017
Error: Elapsed time: 10:30:25
Error: Total CPU time (on all processors): 11:41:19
I have this error in my quartus_sh_compile.log. But this only happens to my designs with large size (70% utilization). It will say 'failed to generate hardware' after around 10 hour's compilation. And by the way, the "<installation directory>/quartus/bin" directory was not in my PATH variable when that happend, but the hardware could be generated for this kernel with small size. I have the quartus_sh_compile.log and <kernel_name>.log attached.
aoc --version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 16.1.0 Build 196
Copyright (C) 2016 Intel Corporation
quartus_map --version
Quartus Prime Analysis & Synthesis
Version 16.1.0 Build 196 10/24/2016 SJ Pro Edition
Copyright (C) 2016 Intel Corporation. All rights reserved
    I see. So if the fitter crushes due to RAM limit, the log file would not say any thing about that?
    Hi
    Can you confirm if your BSP version(if not Altera's board) is match with the SDK version? This error usually link to version miss match.
    CloseCL
    Thanks for your reply!
    I am using altera arria10soc, and below is the board_env_xml,
    <board_env version="16.1" name="altera_a10socdk"><hardware dir="hardware" default="a10soc"/><platform name="arm32"><linkflags>-L%b/arm32/lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b/arm32/bin</utilbindir></platform><platform name="linux64"><linkflags>-L%b/arm32/lib -L%a/host/arm32/lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b/arm32/bin</utilbindir></platform><platform name="windows64"><linkflags>-L%b\arm32\lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b\arm32\bin</utilbindir></platform></board_env>
    And below is my aoc version
    They are all 16.1. (It just cannot finish for a larger size of the design so I think the version should not be the problem?)
    Lancer
    --- Quote Start ---
    --- Quote End ---
    It usually does, but I think there might be cases where it doesn't. If you experience this crash only for large designs, it is certainly not due to Quartus/AOC/BSP version mismatch. As dark_visage suggested, you can try increasing your swap and see what happens. Furthermore, make sure you have the maximum possible amount of free memory before running the compilation. Finally, You can try updating your Quartus and AOC to v16.1.2.
    Thanks for your following up! Yesterday I cleared the RAM and compiled again. The compilation did not crash, but it's still processing until now (it has taken 24+ hours).
