8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years ago --- Quote Start --- I see. So if the fitter crushes due to RAM limit, the log file would not say any thing about that? --- Quote End --- It usually does, but I think there might be cases where it doesn't. If you experience this crash only for large designs, it is certainly not due to Quartus/AOC/BSP version mismatch. As dark_visage suggested, you can try increasing your swap and see what happens. Furthermore, make sure you have the maximum possible amount of free memory before running the compilation. Finally, You can try updating your Quartus and AOC to v16.1.2.
