8 years agoError (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Info: Command: quartus_cdb -t import_compile.tcl Info: Using INI file /home/temp/Desktop/workspace/wisconsin5/wisconsin5/bin/conv/quartus.ini Info (125061): Changed top-level design entity name ...
8 years agoHi,
Thanks for your reply! I am using altera arria10soc, and below is the board_env_xml, <board_env version="16.1" name="altera_a10socdk"><hardware dir="hardware" default="a10soc"/><platform name="arm32"><linkflags>-L%b/arm32/lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b/arm32/bin</utilbindir></platform><platform name="linux64"><linkflags>-L%b/arm32/lib -L%a/host/arm32/lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b/arm32/bin</utilbindir></platform><platform name="windows64"><linkflags>-L%b\arm32\lib</linkflags><linklibs>-lalterahalmmd -lalterammdpcie</linklibs><utilbindir>%b\arm32\bin</utilbindir></platform></board_env> And below is my aoc version Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 16.1.0 Build 196 Copyright (C) 2016 Intel Corporation They are all 16.1. (It just cannot finish for a larger size of the design so I think the version should not be the problem?) Regards, Lancer
