asperkins
1 year agoError (213050): Convert Programming Files was NOT successful
Hey there, I am working on using LiteX to program the DE10Lite FPGA and have begun encountering an error when a Quartus command is evoked from the terminal. I will post the full logs below, but es...
FvM
1 year agoHi,
you are trying to generate .rbf configuration file for MAX10 which isn't supported by CPF tool. MAX 10 has no configuration method that uses .rbf files. What are you trying to achieve?
