Error (213012): Specify a Chain Description File
Hi @YawenLi,
I hope you're doing well.
I managed to duplicate the error you came across at my end by following the command you provided (as shown in the upper part of the coding in the attached screenshot).
However, after I erased the "-o " and typed it again, it can be run successfully without error (as shown in the lower part of the coding).
So, I think it's because of the copy-and-paste issue with the code command. Can you try to erase the "-o " and type it again to see if it can run with no errors?
I hope this helps to resolve your issue.
VenTing_Intel
p/s: If any answers from the community or Intel support are helpful, please feel free to mark them as solutions, give them kudos, and rate the survey 4/5.
Screenshot attached.
