PVanL
4 years agoError 19724: not enough LAB's for clock region
Dear Support, i have this error Error(19724): Fitter requires 628 LABs for clock region in locations from lower-left (13, 32) to upper-right (37, 58), but only 621 LABs are available exclusively for ...
VenT_Altera
4 years agoHi Pieter,
Can you attach the project file? So that I can look into the issue clearer and assist you with that.
Ven Ting
- PVanL4 years ago
Hi Ven,
Thanks for replying. I hope i attached the right files that will help you to identify the issue.
I modified them from e.g. name.qsf to name_qsf.txt, otherwise this tool does not accept them to be attached.
Hope you identify either the issue, or a workaround to get it working.
regards, pieter
