Error (171011): Can't assign node "" to location -- node is type Combinational cell
i get the following message "Error (171011): Can't assign node "FPGA_CLK1_50" to location PIN_AF14 -- node is type Combinational cell
" when i try to assign pins using the pin assignment.
After a bit of searching i see that it used to be an error that happens in older quartus version and for Stratix iii fpga family. However i use quartus 17.1 and Cyclone V device family.
Another point is that i get this error only when using the HLS(high level synthesis) generated ip to connect to a top level verilog module.
It would be great if someone can give me an idea on how to solve this problem.
Many thanks in advance
- AnandRaj_S_Intel
Hi Raj,
I was trying to understand the problem, You have generated a IP using HLS, integrated it in top module and trying to assign a pin which gives you error? Am i right?
We have tried the same with the simple add example for which .IP/.QSYS file is created using HLS and we have used Quartus 17.1 std for integration to top module and assigned a clock pin to AF14 for Cyclone V device 5CSXFC6D6F31C8ES. Attached cmd log and image.
I was not-able to successful replicate the Error mentioned.
However if you can share your .cpp file i can try from my side.
And can you remove the pin assignments and check if fitter is able to place the design successfully with its default assignments
Anand Raj Shankar
- IKomi
Hi Raj,
The possible reason for the issue you faced is using Quartus design generated by HLS compiler and re-assigning virtual pins to physical ones with the Assignment Editor.
Based on my experience, the Assignment Editor might not remove virtual pin assignments from *.qsf file but hide them in its GUI window. Having both virtual and physical pins assigned to the port results in error message "Error (171011): Can't assign node "PIN_..." to location -- node is type Combinational cell." Please search .qsf file of your project in the text editor and comment out/remove undesirable virtual pin assignments.
Igor.
- Miyaxu
helpful
