in5436
1 year agoError (12006): Node instance "inst" instantiates undefined entity "SM1"
While running the Analysis & Elaboration command, I encountered the following error: "Error (12006): Node instance 'inst' instantiates undefined entity 'SM1'". I’ve tried all sorts of things, but t...
ShengN_altera
1 year agoHi,
Could you rename to SM1.bdf?
Sheng
in5436
1 year agoThank you very much! After renaming the file, the error really did disappear. However, it turns out there's another issue now — I’m attaching a screenshot. I’ve already tried renaming everything, but the error still won’t go away. Maybe you know what can be done about it? Thanks in advance, and apologies if I’m doing something wrong.
