josuesantos
2 years agoError 112002 - Can not read any output from quartus_map
Hello, I need help in this problem of my compiler QUARTUS LITE 20.1 When I start Run my project it does go very well, but the problem is in the menssage in the system like Error (112002): Can not ...
sstrell
2 years agoIt looks like you compiled with no files added to the project. The Project Navigator is empty. Where are your design files? Add them from Project menu -> Add/Remove files.
