12 years agoError (10802)
Hi
When I try to compile I have this: Error (10802): VHDL Unconstrained Array error at ide_sd.vhd(7): formal "ID_INIT_FILE" must be constrained Need some help please:confused: The code : library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
-- the ocide controller uses unsigned from here
--use ieee.std_logic_arith.unsigned;
entity ide_sd is
generic
-- when emulating devices accessed using lba mode
-- - use the *default* values
lba_mode : boolean := true;
cylinder_bits : integer := 16;
head_bits : integer := 4;
sector_bits : integer := 8;
id_init_file : string
port
-- clocking, reset
clk : in std_logic;
clk_ena : in std_logic;
rst : in std_logic;
-- ide interface
iordy0_cf : out std_logic;
rdy_irq_cf : out std_logic;
cd_cf : out std_logic;
a_cf : in std_logic_vector(2 downto 0);
nce_cf : in std_logic_vector(2 downto 1);
d_i : out std_logic_vector(15 downto 0);
d_o : in std_logic_vector(15 downto 0);
d_oe : in std_logic;
nior0_cf : in std_logic;
niow0_cf : in std_logic;
non_cf : in std_logic;
nreset_cf : in std_logic;
ndmack_cf : in std_logic;
dmarq_cf : out std_logic;
-- sd/mmc interface
clk_25m : in std_logic;
sd_dat_i : in std_logic_vector(3 downto 0);
sd_dat_o : out std_logic_vector(3 downto 0);
sd_dat_oe : out std_logic;
sd_cmd_i : in std_logic;
sd_cmd_o : out std_logic;
sd_cmd_oe : out std_logic;
sd_clk : out std_logic
end entity ide_sd;
