Error (10500): VHDL syntax error at mux5to1.vhd(15) near text "IN"; expecting an identifier ("in" is a reserved keyword), or a string literal what is the problem?
SIGNALs do not have IN/OUT designations. It should be:
SIGNAL m0,m1,m2: STD_LOGIC_VECTOR(2 DOWNTO 0);
The error is pushed down to line 15 because that's the first line after this error.
#iwork4intel
- sstrell
#iwork4intel
- gAcqu
thanks
- gAcqu
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
ENTITY mux5to1 IS
PORT (x: IN STD_LOGIC_VECTOR(14 DOWNTO 0) ;
s : IN STD_LOGIC_VECTOR(17 DOWNTO 15) ;
f : OUT STD_LOGIC_VECTOR(2 DOWNTO 0)) ;
END mux5to1 ;
ARCHITECTURE Structure OF mux5to1 IS
SIGNAL m0,m1,m2: OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
COMPONENT mux2to1
PORT( x,y: IN STD_LOGIC_VECTOR(2 DOWNTO 0) ;
s : IN STD_LOGIC ;
f : OUT STD_LOGIC_VECTOR(2 DOWNTO 0) ) ;
END COMPONENT ;
BEGIN
Mux1: mux2to1 PORT MAP
( x(14 downto 12),x(11 downto 9), s(15), m0(2 DOWNTO 0)) ;
Mux2: mux2to1 PORT MAP
( x(8 downto 6),x(5 downto 3), s(15), m1(2 DOWNTO 0)) ;
Mux3: mux2to1 PORT MAP
( m0(2 DOWNTO 0),m1(2 DOWNTO 0), s(16), m2(2 DOWNTO 0)) ;
Mux4: mux2to1 PORT MAP
( m2(2 DOWNTO 0),x(2 downto 0), s(17), f) ;
END Structure ;
