9 years agoError 10500 Syntax Error?
Hi there,
could anyone please point out what is wrong with my code as I don't see anything that is wrong with it? It won't compile and is giving me error 10500 code:library ieee;
use ieee.std_logic_1164.all;
entity sev_seg_deco is
port
( SW : in std_logic_vector(2 downto 0);
HEX0 : out std_logic_vector(6 downto 0);
end sev_seg_deco;
architecture behav of sev_seg_deco is
begin
with SW select
HEX0 <= "1110110" when "000",
"1111001" when "001",
"0111000" when "010",
"0111111" when "011",
"1000000" when others;
end architecture behav; error codes:
error (10500): vhdl syntax error at sev_seg_deco.vhd(9) near text "end"; expecting an identifier ("end" is a reserved keyword), or "constant", or "file", or "signal", or "variable" Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 1 warning Error: Peak virtual memory: 630 megabytes Error: Processing ended: Sun May 21 17:52:09 2017 Error: Elapsed time: 00:00:09 Error: Total CPU time (on all processors): 00:00:18 Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 1 warning Any assistance is greatly appreciated, thank you
port( SW : in std_logic_vector(2 downto 0); HEX0 : out std_logic_vector(6 downto 0) ); end sev_seg_deco; - Altera_Forum
Thank you! I just emailed my lecturer and got the same response, I was looking at that for ages...
--- Quote Start ---
--- Quote End ---port( SW : in std_logic_vector(2 downto 0); HEX0 : out std_logic_vector(6 downto 0) ); end sev_seg_deco; - Altera_Forum
In case it's not obvious for others reading this, the last port in the port list should not end with a semicolon.
