9 years ago
Error (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"
Hi every one i m using quartus 11.0 sp1 on the ubuntu and got the following error in my code can any body help me how to remove this error.thanks in advance
error
code
library ieee;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
use IEEE.math_real.CEIL;
use IEEE.math_real.LOG;
use ieee.std_logic_1164.all;
library work;
use work.all;
entity firTree32tap is
generic (
DATA_WIDTH : integer := 16
port(
i : in std_logic_vector(DATA_WIDTH-1 downto 0);
c8 : in std_logic_vector(15 downto 0);
c9 : in std_logic_vector(15 downto 0);
c10 : in std_logic_vector(15 downto 0);
c11 : in std_logic_vector(15 downto 0);
c12 : in std_logic_vector(15 downto 0);
c13 : in std_logic_vector(15 downto 0);
c14 : in std_logic_vector(15 downto 0);
c15 : in std_logic_vector(15 downto 0);
c16 : in std_logic_vector(15 downto 0);
c17 : in std_logic_vector(15 downto 0);
c18 : in std_logic_vector(15 downto 0);
c19 : in std_logic_vector(15 downto 0);
c20 : in std_logic_vector(15 downto 0);
c21 : in std_logic_vector(15 downto 0);
c22 : in std_logic_vector(15 downto 0);
c23 : in std_logic_vector(15 downto 0);
c24 : in std_logic_vector(15 downto 0);
c25 : in std_logic_vector(15 downto 0);
c26 : in std_logic_vector(15 downto 0);
c27 : in std_logic_vector(15 downto 0);
c28 : in std_logic_vector(15 downto 0);
c29 : in std_logic_vector(15 downto 0);
c30 : in std_logic_vector(15 downto 0);
c31 : in std_logic_vector(15 downto 0);
--PARAM
c0 : in std_logic_vector(15 downto 0);
c1 : in std_logic_vector(15 downto 0);
c2 : in std_logic_vector(15 downto 0);
c3 : in std_logic_vector(15 downto 0);
c4 : in std_logic_vector(15 downto 0);
c5 : in std_logic_vector(15 downto 0);
c6 : in std_logic_vector(15 downto 0);
c7 : in std_logic_vector(15 downto 0);
--PARAM
o : out std_logic_vector((2*DATA_WIDTH)-1+31 downto 0);
clk : in std_logic
end firTree32tap;
architecture behavior of firTree32tap is
constant numLevels : integer := integer(CEIL(LOG(real(DATA_WIDTH), 2.0)))+1;
type intermediate_t is array (0 to 32) of std_logic_vector((2*DATA_WIDTH)-1+31 downto 0);
signal intermediate : intermediate_t := (others => (others => '0'));
type coef_t is array (0 to 31) of std_logic_vector(DATA_WIDTH-1 downto 0);
signal coef : coef_t;
type mult_t is array (0 to 31) of std_logic_vector((2*DATA_WIDTH)-1 downto 0);
signal mult1 : mult_t;
signal i_buffered : std_logic_vector(DATA_WIDTH-1 downto 0);
begin
coef(0) <= c0;
coef(1) <= c1;
coef(2) <= c2;
coef(3) <= c3;
coef(4) <= c4;
coef(5) <= c5;
coef(6) <= c6;
coef(7) <= c7;
coef(8) <= c8;
coef(9) <= c9;
coef(10) <= c10;
coef(11) <= c11;
coef(12) <= c12;
coef(13) <= c13;
coef(14) <= c14;
coef(15) <= c15;
coef(16) <= c16;
coef(17) <= c17;
coef(18) <= c18;
coef(19) <= c19;
coef(20) <= c20;
coef(21) <= c21;
coef(22) <= c22;
coef(23) <= c23;
coef(24) <= c24;
coef(25) <= c25;
coef(26) <= c26;
coef(27) <= c27;
coef(28) <= c28;
coef(29) <= c29;
coef(30) <= c30;
coef(31) <= c31;
intermediate(0) <= (others => '0');
BUF:process(clk)
begin
if clk'event and clk='1' then
i_buffered <= i;
end if;
end process BUF;
TAPS: for index in 1 to 32 generate
MULTIPLIER:entity work.mult16bit
generic map (
DATA_WIDTH => DATA_WIDTH
port map (
a => i_buffered,
b => coef(index-1),
c => mult1(index-1)
SUM:process(clk)
begin
intermediate(index) <= STD_LOGIC_VECTOR(UNSIGNED'(UNSIGNED(intermediate(index-1)) + UNSIGNED(mult1(index-1)))) ;
end if;
end process SUM;
end generate TAPS;
o <= intermediate(32);
end behavior;
    I dont think you posted the entire error, but given the line number, I suspect the work library does not contain the mult16bit entity. Have you compiled it before this file?>
    --- Quote Start ---
    --- Quote End ---
    yes i complied it before and the mult16bit is in the libray but it gives that error.
    before this i make 8 bit code its working completely with mult8bit now i want to make 16 bit code but it gives that error . what your suggestion?
    Please can you post all of the error?
    As a side not, why is it called Mult16bit when it has a DATA_WIDTH generic?
    --- Quote Start ---
    --- Quote End ---
    Error (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"does not contain primary unit "mult16bit"
    --- Quote Start ---
    --- Quote End ---
    This error implies you have NOT compiled a file containing the mult16bit entity. Please check your project settings to ensure the file is included, and ensure that the entity inside the file is named correctly (remember its the entity name thats important, not the file name).
