9 years agoError (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"
Hi every one i m using quartus 11.0 sp1 on the ubuntu and got the following error in my code can any body help me how to remove this error.thanks in advance error Error (10481): VHDL Use Clau...
9 years ago --- Quote Start --- Please can you post all of the error? As a side not, why is it called Mult16bit when it has a DATA_WIDTH generic? --- Quote End --- Error (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"does not contain primary unit "mult16bit"
