9 years agoError (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"
Hi every one i m using quartus 11.0 sp1 on the ubuntu and got the following error in my code can any body help me how to remove this error.thanks in advance error Error (10481): VHDL Use Clau...
9 years ago --- Quote Start --- Error (10481): VHDL Use Clause error at firTree32tap.vhd(118): design library "work"does not contain primary unit "mult16bit" --- Quote End --- This error implies you have NOT compiled a file containing the mult16bit entity. Please check your project settings to ensure the file is included, and ensure that the entity inside the file is named correctly (remember its the entity name thats important, not the file name).
