18 years agoError 10327: Can't determine definition of operator ""+""
Hello to everybody, could someone tell me what's wrong in the following code? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity round16to12 is ...
8 years agoHello,
I'm getting the same error that is mentioned many times in this topic.. Error (10327): VHDL error at ADD_SUBB.vhd(31): can't determine definition of operator ""+"" -- found 0 possible definitions This is my code.. What am i doing wrong? Already many thanks for your help! :) -- Library Declaration LIBRARY ieee; USE ieee.numeric_std.all; USE ieee.std_logic_1164.all; -- Entity Declaration entity ADD_SUBB is port ( a : in std_logic_vector (3 downto 0); -- Input A b : in std_logic_vector (3 downto 0); -- Input B sel : in std_logic; -- ADD/SUB, Go's to mux to choose if it is SUB or ADD. r : out std_logic_vector (3 downto 0); -- Result of ADD or SUB ovf : out std_logic; -- Overflow, when result is above 15 sign : out std_logic -- + or - ); end ADD_SUBB; -- Architecture Body architecture RTL of ADD_SUBB is signal c : std_logic_vector (3 downto 0); -- sum of adder signal d : std_logic; -- overflow of adder signal e : std_logic_vector (3 downto 0); -- sum of subtractor signal f : std_logic; -- sign bit +/- Begin process (a,b) -- Add function. variable p: std_logic_vector (4 downto 0 ); begin p := '0' & a + '0' & b; c <= p(3 downto 0) after 5ns; d <= p(4) after 5ns; end process; process(a,b) -- Sub function. begin p := '0' & a - '0' & b; e <= p(3 downto 0) after 5ns; f <= p(4) after 5ns; end process; process(c,d,e,f,sel) -- Decoder(mux) begin if sel = '1' then r <= c; ovf <= d; else r <= e; sign <= f; end if; end process; end architecture;
