MamaSaru
2 years agoeq output of lpm_counter does not see higher q bits in simulation.
I found the error in simulation library source file 220model.v. #3866 assign eq = tmp_eq; should be: assign eq = (final_count < 16) ? tmp_eq : 0; to confirm higher q bits are all zero. My simul...
- 2 years ago
Richard,
No thanks, it was just feedback to Questa.
Thank you for your effort.
MamaSaru
2 years agoHi Richard,
Thank you for the reply.
I did not find any other problem for now.
I already revise 220model.v file and compile it with other RTL files in my project.
My design is the backend part of Arria 10 PCI Express avalon ST IP.
I can't send whole my project but instead I will send one module that instantiate lpm_counter.
You can simulete this module but you may not need to do.
Please read lpm_counter module definition in 220model.v, you can see eq output never get all zeros.
