MamaSaru
2 years agoeq output of lpm_counter does not see higher q bits in simulation.
I found the error in simulation library source file 220model.v. #3866 assign eq = tmp_eq; should be: assign eq = (final_count < 16) ? tmp_eq : 0; to confirm higher q bits are all zero. My simul...
- 2 years ago
Richard,
No thanks, it was just feedback to Questa.
Thank you for your effort.
FvM
2 years agoHi,
I suspect there are more faults. Do you understand the idea behind tmp_eq?
B.T.W., there's apparently a longer tradition of incorrect lpm_counter models. Modelsim_AE was never using eq in 220model.v, simply zeroing it.
assign eq = {16{1'b0}};
No idea if the limitations are specified somewhere?
