11 years ago
entity problem/errors with easy counter
Hello guys,
I am new to VHDL, but I am having some problem with my entitiy creation. The design below counts the number of leading zeros in a binary vector, starting
from the left end. But i am not able to compile my file at all thats why I need your help.
This is the error message I got:
Error (10500): VHDL syntax error at zero_counter.vhd(5) near text "ENTITY"; expecting "(", or "'", or "."
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all
ENTITY zero_counter IS -- error message at this point
GENERIC (WID: Integer :=8;
Minval: unsigned:="0000_0000"
PORT(data: IN STD_LOGIC_VECTOR(WID-1 downto 0);
output: OUT STD_LOGIC_VECTOR(WID-1 downto 0)
END zero_counter;
ARCHITECTURE behavior OF zero_counter IS
BEGIN
PROCESS (data)
VARIABLE count: unsigned (0 to WID-1);
BEGIN
count := Minval;
FOR i IN 0 to Wid-1 LOOP
CASE data(i) IS
WHEN '0' => count := count + 1; -- data(i)='0' , count++
WHEN OTHERS => NEXT; --jump to next iteration
END CASE;
END LOOP;
output <= std_logic_vector(count);
END PROCESS;
END behavior;
I already tryed to realize it without the generic block, but its all the same.
I am using Quartus 13.1
Can someone help me?
