GMcCa2's avatar
GMcCa2
6 years ago
Enable assert statement output to messages in Quartus Prime Pro?
I've started using Quartus Prime Pro (currently using 19.4) and have noticed that it does not output VHDL assert statements to the messages during compilation like Quartus Standard does. It also doesn't error when it hits an assert statement that evaluates to false with severity set to error. Is there a way to enable it to process assert statement in VHDL during compilation like it does in Standard?
We're using assert statement throughout our design to validate parameters and to provide messages that are used to verify the design is setup right when there are issues. This is a show stopper for us if we can't get this working.
  • sstrell's avatar
    sstrell
    ASSERT is not typically a synthesizable construct so I'm surprised this ever displayed anything during a compilation in Quartus standard. It's meant for simulation only.
    I do see in Quartus help that there are messages that can be displayed for ASSERT, so it's possible that the move to Pro, with a synthesis engine that more closely follows the IEEE standards which say to ignore ASSERT during synthesis, that this feature was removed. Can you provide code example(s)? That might help to see if there's an equivalent to what you're trying to do.
    #iwork4intel
    • GMcCa2's avatar
      GMcCa2
      We commonly using assert to do checks on parameters during synthesis:
      entity SomeEntity is
        generic map
          DATA_WIDTH  : natural
      port map
        data  : std_logic_vector(DATA_WIDTH-1 downto 0)
      end entitiy;
      architecture arch of SomeEntity is
      begin
        assert DATA_WIDTH < 10 report "Data widths larger than 10 are not supported" severity error;
      end architecture;
      We also use it to simple output a message about what was compiled for future reference.
        generic map
          CONFIG1 : complex_record_type
      port map
        -- some ports
      end entitiy;
      function complex_enable_check(config: complex_record_type) return boolean is
      begin
        -- A complex function here that return a boolean based on a complex configuration record
      end function;
      begin
        assert false report "Config1 value1 is " & integer'image(CONFIG1.value1) severity note;
        assert false report "Config1 value2 is " & integer'image(CONFIG1.value2) severity note;
        genBlock: if complex_enable_check(CONFIG1 ) generate
          assert false report "<Design block name> is enabled" severity note;
         -- Design block here
        end generate;
      end architecture;
      We use complex record types and function in many place in our design that enable different blocks of code and it's useful to be able to output their values and results during synthesis. This allows us to look back at the message outputs when we have problems to help figure out the problem. Some of the function we use are hundreds of line of VHDL and many of our configuration type are records with many layer of nested records and arrays, so it's often not easy to understand what is happening without assert statements.
      Any suggestions you have for alternatives would be appreciated.
    • BCuze's avatar
      BCuze
      Dear Honored Contributor,
      Sorry to say that "Beginner" is absolutely right in his demand.
      "Assertions are not for synthesis" is a lame joke. The Assertion statement has always been working perfectly in Quartus Prime Std !
      I suggest you refer to the Quartus Manual (see screenshot) and file this big parser bug to be corrected, as we are so many to ask.
      And I'm surprised you didn't notice that it does affect Intel own IPs.
      The ability for an IP to stop the compilation when something is wrong in the settings is not a gadget.
      Bert
  • Phil-W's avatar
    Phil-W
    Did you resolve this? I used this technique in the past and would like to use it again but it seems newer versions of Quartus don't support it?
