Enable assert statement output to messages in Quartus Prime Pro?
ASSERT is not typically a synthesizable construct so I'm surprised this ever displayed anything during a compilation in Quartus standard. It's meant for simulation only.
I do see in Quartus help that there are messages that can be displayed for ASSERT, so it's possible that the move to Pro, with a synthesis engine that more closely follows the IEEE standards which say to ignore ASSERT during synthesis, that this feature was removed. Can you provide code example(s)? That might help to see if there's an equivalent to what you're trying to do.
#iwork4intel
We commonly using assert to do checks on parameters during synthesis:
entity SomeEntity is
generic map
DATA_WIDTH : natural
port map
data : std_logic_vector(DATA_WIDTH-1 downto 0)
end entitiy;
architecture arch of SomeEntity is
begin
assert DATA_WIDTH < 10 report "Data widths larger than 10 are not supported" severity error;
end architecture;We also use it to simple output a message about what was compiled for future reference.
generic map
CONFIG1 : complex_record_type
port map
-- some ports
end entitiy;
function complex_enable_check(config: complex_record_type) return boolean is
begin
-- A complex function here that return a boolean based on a complex configuration record
end function;
begin
assert false report "Config1 value1 is " & integer'image(CONFIG1.value1) severity note;
assert false report "Config1 value2 is " & integer'image(CONFIG1.value2) severity note;
genBlock: if complex_enable_check(CONFIG1 ) generate
assert false report "<Design block name> is enabled" severity note;
-- Design block here
end generate;
end architecture;We use complex record types and function in many place in our design that enable different blocks of code and it's useful to be able to output their values and results during synthesis. This allows us to look back at the message outputs when we have problems to help figure out the problem. Some of the function we use are hundreds of line of VHDL and many of our configuration type are records with many layer of nested records and arrays, so it's often not easy to understand what is happening without assert statements.
Any suggestions you have for alternatives would be appreciated.
