EMIF Toolkit
Hi David,
Please check the "emif_0_status_local_cal_fail" and "emif_0_status_local_cal_success" with signaltap. If none of them toggles please check the ddr4 reference clock. Make sure it becomes stable before the FPGA configuration done.
Aaron
- David322 years ago
Hi Aaron,
The DDR4 reference clock was not stable when FPGA entered user mode.
I have fixed this and now the "Create Memory Interface Connection" within EMIF Toolkit does complete OK.
However - there are some remaining issues withe the toolkit and the DDR4 interface.
1.
I have tested W/R to the DDR4 from within the system console.
Up to a certain address (0xF000) the memory seems to work OK - although the number of runs was very small.
From 0xF000 the DDR4 is always reading 0x0.
2.
Any action that I try to perform within the toolkit, such as recalibration, or margining, etc, leads to an endless loop within the tool - where I am told to WAIT.
Any help on solving the above two issues would be greatly appreciated.
David
- zhenruan2 years ago
Hi David,
For a10 device how do you write and read to the DDR4 from within the system console? I don't think you can control the traffic in this way. The TG module controls the data pattern and customer can't control the TG module. You can change the TEST_DURATION mode for the TG as the guide below:
To do the recalibration, please create Memory Interface Connection first.
After that run the recalibration:
Please refer to the link below for more information on the operation for the Driver Margining:
Aaron
Hi Aaron,
I will answer your questions in order:
1. Since the EMIF Toolkit was not working, I added a JTAG Master to the QSYS, and temporarily removed the TG from the design.
2. Using EMIF Toolkit, as I stated previously, I am doing all the steps up to, and including, Create Memory Interface Connection.
However, after that point, when I try something like "Rerun Calibration", the Toolkit seems to enter an endless "WAIT" loop.
I am NOT trying to exercise the TG, since I temporarily removed it from the design.
Some more information though:
Using system console, I can see two Masters as seen below:
When I run manual memory tests (just write and read back) from the console I see a few interesting things:
1. Write/Read seem to work OK up to address 0xF000
2. The addresses seem to wrap around at 0x100_0000, 0x200_0000, etc.
Any ideas?
David
