EMIF link project error in Quartus 18.0
- 2 years ago
Hi Adzim,
Error message (0x80070005) was resolved by enabling JTAG server apps to communicate through "Private" and "Public" profile in Windows Defender Firewall.
After resolving this Error message (0x80070005), I still face the same issue of executing:
"{C:/intelfpga/18.1/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt"
I eventually figure out that Quartus Prime 18.1 std can't work with wsl (windows subsystem for linux).
(The reason i enabled wsl in the first place was because i have both Quartus P 18.1 std and 22.1 in the same PC. And Quartus P 22.1 need WSL to compile ddr3 ip.)
So i resolved the ddr3 IP compilation by unchecking Windows Subsystem for Linus in Windows Features.
Is the issue still exist at your end?
From the error messages, it's seem the issue is related to firewall.
Firewall setting can interfere with JTAG server.
Can you please check with your admin once.
We don't have any setting to tell Platform Designer to leave the firewall alone.
Adzim
