EMIF link project error in Quartus 18.0
- 2 years ago
Hi Adzim,
Error message (0x80070005) was resolved by enabling JTAG server apps to communicate through "Private" and "Public" profile in Windows Defender Firewall.
After resolving this Error message (0x80070005), I still face the same issue of executing:
"{C:/intelfpga/18.1/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt"
I eventually figure out that Quartus Prime 18.1 std can't work with wsl (windows subsystem for linux).
(The reason i enabled wsl in the first place was because i have both Quartus P 18.1 std and 22.1 in the same PC. And Quartus P 22.1 need WSL to compile ddr3 ip.)
So i resolved the ddr3 IP compilation by unchecking Windows Subsystem for Linus in Windows Features.
The error messages indicate that your design has different device with the board.
Can you verify if the design is using same device as the board?
Adzim
