jdoherty
6 years agoElaboration error in Merlin router
I am having an issue with elaborating generated files from a Platform Designer project. I inherited a CPU project and needed to add interfaces to it so I could connect it to other Avalon bus...
- 6 years ago
Can you try an experiment and add an Avalon to External bus Bridge and then connect a slave to that to see if that compiles?
SyafieqS
6 years agoHi Joseph,
I found a KDB related to your issue, might have to see it
jdoherty
6 years agoHi,
I've tried moving one of the slaves up to 0x7800_0000-0x7803_ffff but that didn't seem to work. I also grouped all of the new slave interfaces into one and gave that a larger address width which also didn't work.
- NG6 years ago
- jdoherty6 years ago
Thank you, that did compile.
Any idea why there is a difference between the External bus Bridge and the Slave Translator?
