Eclipse for Nios II Unrecognized Func Def
The problem and steps I've taken is outlined in the following post:
https://forums.freertos.org/t/definitions-port-c-alt-ic-irq-disable-enable/18579
Despite this being a topic in a previous discussion board (https://community.intel.com/t5/Intel-Quartus-Prime-Software/Why-I-can-not-find-the-alt-irq-enable-function-in-HAL-src/td-p/174843) the fix applied does not work for me. The program is simply the standard FreeRTOS build and although the function definition is there, the compiler keeps giving me a makefile 1033 error and "undefined reference to alt_ic_irq_enable/disable" errors. And the definition is in a file that's been included. I'm not sure where to go from here to further troubleshoot the issue.
Thanks in advance!
Based on the forum link you attached, it seems you already found the solution. Do you able to solve it already?
- wwanalim_intel
Contributor
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
- wwanalim_intel
Contributor
- road_runner
I apologize for not responding to this thread sooner. Yes, the solution worked for me. Thanks!
- wwanalim_intel
Contributor
It seems the issue already been solved in this forum below.
- wwanalim_intel
Contributor
