Downgrade from Pro to Standard?
- FvM
Std and Pro are separate Installations, no downgrade possible. You can keep the Pro installation unless you run out of disc space. - SyafieqS
You need Quartus standard. they are separate installation.
You need to donwload Std version
- sstrell
And no need to downgrade the license. Same license for Pro and Standard.
- SyafieqS
Let me know any update.
- Mahmoud_Hashem
Can I work on Quartus Prime Standard with "Questa*-Intel® FPGAs Pro Edition Software Version 23.3"? or should I use the "Questa*-Intel® FPGAs Standard Edition Software Version 22.1.2"?
And may I know what is the difference between those and Starter Edition?I want to know what version that will support the SystemVerilog verification capabilities.
- sstrell
Comparison and support (all editions) is here: https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/questa-edition.html
- SyafieqS
Questa std should be working with Quartus STD. I suggest to install new Quartus STD package. Lot easier.
- SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
